Reverse light
ram250098
69 Barracuda
Cookstown Ontario Canada
Going through the car today doing some electrical clean up, noticed the reverse 4 speed light is not hooked up, after looking couldn't find where the connection is?
Looking into the dome light today as well, took the whole dome fixture down and another mouse fell out...good thing I am redoing all the interior...hate those litte vermen bastards LOL
AL
You can't find the wires, or you can't find where the switch is? The switch is on the main trans case, in back of the side cover and in front of the speedo pinion. Could be that the electrical spades are busted off... Brewers has new ones. www.brewersperformance.com
The spade is on the end of the wire but the wire was not hooked up and just tucked under the carpet. I guess it must run through the firewall instead the floor?
Thanks
AL
Mine goes though the block on the fire wall. Then from their it connects with one of the wires going to the reverse switch on the tranny.
Fred B
Fred B
That's the way I have mine wired. I had to replace the switch to get it to work.
See now that makes sense LOL The wire was under the carpet over by the shifter, it seemed odd, so I just figured it went throught the floor.
Thanks guy's
AL
