Rhoads lifters
joes68340s
Rescue CA.
Has anyone used Rhoads lifters. I want to pickup a little bit more idle quality and some bottom end. Do they work or just a waste of time. I am trying to save this engine for one more season before I go for a new setup.
They do work, but they usually sacrifice a little noise. You may hear some ticking with them at idle.
Noise right now is not an issue. just want to pick up a little more bottom end with this combination.
Combo dependent....
I used them with a Mopar 288 circle track cam. It did the trick, Smoothed idle, boosted low end torque. You will notice.
Thanks thats what Im looking for. Just want to use this combo one more season. Thanks again.
Joe , I too have used them and they do work. But keep in mind since they work off of oil pressure...if you use a Hi-pressure oil pump..you will defeat thier purpose. Good luck, Terry.
