I have a 67 Dart G/T. I REALLY like the Rimblow steering wheels. Can I install one in my 67 and if so, what do I have to do?
Thanks all!
Thanks all!
What year is your dart though? I just put the adapter up to my steering column and it seems to be almost an inch wider than the coupler on my steering column. Curious if this only works for 70 and up darts.I did in mine was not bad just get the parts and the gound wire should be in the column, hook it up and beep beep.
stock rim blow. Do you have any pics?Mine is a 1967,are you talking about a stock wheel or after market?
Yes, I am talking about the rim blow steering wheel that was available on 70 and 71 cudas and Challenger's and also available on 71 darts. I know there is an adapter needed, which I have. But it seems to be wider than my steering column on my 67. Was wondering if this would only work on 70 up steering columns.Are you talking about the wheel off a Cuda ?
