[FOR SALE] Rims and tires
5.7 hemi
i have a set of rims/tires from American Racing. The fronts are 17x8 with Goodyear Eagle Gt's, tire size us 245-40-17 and they have 500 miles on them. The rear is 275-40-17 Nitto 555 and they are new!
Backspace for the front rims are 4.5 inch and the rear is 6 5/8ths. There are 2 fronts and 2 rears. Asking 650 obo plus the ride or local pick up from 93230.
Can deliver to fall fling if paid for in advance.
WOW .. 275 in the rear ... I have a 70 dart with an 8 1/4 and disk up front ...
can i even get these inside the rear wells ?... was your a-body mini tubed ..
No, it was stock but have decided to go bigger, so now I'm in the process of mini tubbing it.
As far as I know, your car has a bit more room in the back than mine. I can't say for certain that they will fit or will not fit.
Forgot to add I have an extra rear rim that goes with the sale.
I had them on my 69' Dart GT, using them as rollers as I'm still building the car.
ok .. im not sure they will fit .. i just put a tape to the car and an 6 5/8 back would put it agents the rear springs ..
so i would love to have them but i dont see how they would fit ... unless the rear spring where moved in
So ill pass ..
Thanks David
That's a given.....gotta move the springs inward for this size rim to fit.
Other option is to use a B Body housing to move the wheels out 1 inch per side in the back.
