69Chrgr
Charger/Cuda
Hey guys,
Installed my rings on the pistons yesterday EXACTLY as shown on the ring packages. It showed the top piston ring chamfer pointing down, just like the second ring. Called Indy and they said that the top ring chamfer should be pointing up. There was no dot on the top ring to show which way. There was a dot on the second ring however. Now I have to remove all 8 pistons and rods and reinstall the top ring. What give? Have any of you had this problem? So the chamfer on the top ring should point up? Any advice appreciated!
