Rocker arm recommendations?
Big Block A body Tech
  1. dukeboy_318
    dukeboy_318 FABO Gold Member FABO Gold Member
    44,540
    20360
    Jan 19, 2007
    No
    Local Time:
    4:48 AM
    Finishing my order list tonight, just curious before I pull the trigger, besides Comp or Harland Sharp roller rockers, 1.5s, is there any other brands I should consider for reliability and durability? 440 with roller cam and RPM heads.
  2. fishmens67
    fishmens67 Well-Known Member
    10,566
    9277
    Nov 10, 2012
    idaho
    Local Time:
    3:48 AM
    PRW stainless
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • dano
      dano Evil Handy Man
      3,895
      1720
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      1:48 AM
      Hughes. Worked great on my SpeedMaster LA heads and my dads 915, 440 heads.
      • Agree Agree x 1
      • yellow rose
        yellow rose Overnight Sensation FABO Gold Member
        28,824
        25246
        Jun 19, 2015
        Central Washington
        Local Time:
        1:48 AM
        Call Mike at B3 Racing Engines and let him help you.
        • Agree Agree x 4
        • Heywodja
          Heywodja The Heartbeat Stops Here FABO Gold Member
          870
          496
          Aug 16, 2014
          Texas
          Local Time:
          3:48 AM
          ^^^^^^^^^ what he said ^^^^^^^^^
        • jas0162
          jas0162 Well-Known Member
          596
          392
          Apr 23, 2014
          kansas
          Local Time:
          3:48 AM
          I bought Hughes for my stroker motor. I dont like all the little needle bearings.
          • Agree Agree x 3
          • dano
            dano Evil Handy Man
            3,895
            1720
            Aug 22, 2005
            Gresham, Oregon
            Local Time:
            1:48 AM
            Neither set from Hughes we used had needle bearings unless your talking about the roller tips?
            • Agree Agree x 1
            • Bewy
              Bewy Well-Known Member
              773
              445
              Jan 1, 2021
              Australia
              Local Time:
              6:48 PM
              I have just bought Comp rockers, steel. Look strong, haven't used them yet.
              I would think twice about advice from B3 racing. There is a glaring fault in Part 2 of the rocker tech. Third paragraph, first line. He claims the rocker ratio [ on the valve/roller tip side ] remains constant through out the rocker's travel. It does not. If that basic premise is wrong, then I wonder about the rest of the advice....
              • Thanks! Thanks! x 2
              • Disagree Disagree x 2
              • Like Like x 1
              • Agree Agree x 1
              • famous bob
                famous bob mopar misfit
                19,371
                8689
                Aug 14, 2011
                okla
                Local Time:
                3:48 AM
                I have had excellant service out og Hughs engines rocker arms so far----
                • Like Like x 1
                • famous bob
                  19,371
                  8689
                  Aug 14, 2011
                  okla
                  Local Time:
                  3:48 AM
                  No bearings in my hughs rockers , anywhere !!
                  • Agree Agree x 3
                  • Like Like x 1
                  • Brooks James
                    Brooks James Dustoff
                    1,243
                    623
                    Dec 12, 2020
                    Fruitland Park Fl
                    Local Time:
                    4:48 AM
                    Harland Sharp but$$$$$
                  • Bighead440
                    Bighead440 Well-Known Member
                    365
                    285
                    Jun 18, 2017
                    Milledgeville, Georgia
                    Local Time:
                    4:48 AM
                    The bushed PRW stainless or Crane/Hughes (aluminum on shaft "bearing") work great and maintain oil pressure within the shaft better than the bleed-off you get with needle-bearing fulcrum rockers. This is very important if you have full time rocker oiling, which would need to be regulated/restricted with an orifice when using the needle-bearing rockers.
                    • Like Like x 1
                    • yellow rose
                      28,824
                      25246
                      Jun 19, 2015
                      Central Washington
                      Local Time:
                      1:48 AM
                      I was going to add my .02 cents but I figured you have it all figured out. A simple phone call will clear up any misunderstanding but that would require effort.
                      • Like Like x 2
                      • Disagree Disagree x 1
                      • mygasser
                        mygasser FABO Gold Member FABO Gold Member
                        1,059
                        701
                        Aug 17, 2010
                        faversham, kent. united kingdom
                        Local Time:
                        3:48 AM
                        i think he meant he bought hughes rockers 'because' he didn't like needle roller bearings (that some others have). that's how i read it anyway :thumbsup:
                        • Agree Agree x 3
                        • Like Like x 2
                        • jas0162
                          596
                          392
                          Apr 23, 2014
                          kansas
                          Local Time:
                          3:48 AM
                          I bought the Hughes rockers BECAUSE THEY DONT HAVE the needle bearings. Sorry for the confusion
                          • Like Like x 1
                          • AndyF
                            AndyF Well-Known Member
                            1,956
                            2200
                            Feb 23, 2009
                            Oregon
                            Local Time:
                            1:48 AM
                            A steel rocker arm is the best for reliability and durability. Not a lot of steel rockers on the market though. Comp makes a good set, RAS are great rockers if you can find them. The factory nodular rockers work fine if you can find them or old Isky nodulars if they haven't been abused. I run RAS on my engines but they are hard to come by.
                            • Like Like x 4
                            • famous bob
                              19,371
                              8689
                              Aug 14, 2011
                              okla
                              Local Time:
                              3:48 AM
                              THANKS , but I run .650 offset intakes ----
                            • Krooser
                              Krooser Reform School Graduate
                              3,192
                              2744
                              Jul 19, 2015
                              Central Wisconsin
                              Local Time:
                              3:48 AM
                              T&D...
                            • moparmarks
                              moparmarks zippindippintie FABO Gold Member
                              1,659
                              881
                              Oct 5, 2014
                              Western Colorado
                              Local Time:
                              2:48 AM
                              I wouldn't use anything made by Comp. Total junk.
                              • Agree Agree x 1
                              • dukeboy_318
                                44,540
                                20360
                                Jan 19, 2007
                                No
                                Local Time:
                                4:48 AM
                                Based on?
                              • moparmarks
                                1,659
                                881
                                Oct 5, 2014
                                Western Colorado
                                Local Time:
                                2:48 AM
                                Lifter failure. Cam failure. Rocker arm failure. On multiple motors during break in on the dyno. My machinist had two sets of their roll rockers fail during break in on the dyno on two different motors. I know of several different people including myself that have had many problems with Comp products. Call their customer service and they pretty much call you an idiot.
                                comp cam problems - Google Search
                                comp cam rocker problems - Google Search
                              • B3RE
                                B3RE B³ Racing Engines
                                616
                                657
                                Aug 22, 2013
                                USA
                                Local Time:
                                4:48 AM
                                Everyone is entitled to their opinion, but from an engineering perspective, a PROPERLY DESIGNED roller rocker will have a constant ratio. The effective fulcrum length does not change. But, good luck finding an off the shelf rocker that is properly designed. The only way to get that is a custom rocker. If the pushrod side is not designed with proper valve side geometry in mind, then the ratios will not necessarily be constant because the lobe lift inputs will be inaccurate and skew the results at the valve.
                                If that is the sole reason to discredit my work, then I guess there are a lot of companies that shouldn't be believed due to the sketchy info they promote. Ever read the Harland Sharp website on rocker geometry? How about Comp Cams info on rocker geometry? If you want to read or watch videos on something that doesn't make sense, you might want to start there, and you can find a whole lot more. In the end, I stand by my assertion that a properly designed roller rocker will have a constant ratio, and you will never achieve that with a shoe type rocker. Even a poorly designed roller rocker will do a better job than a shoe rocker, or there would be no point in having a roller.
                                I'm not afraid to admit I can, and do, make mistakes, and I have been wrong before. But, to discount everything I have learned over the years, over one thing you happen to disagree with, seems a bit over the top, imo.
                                • Like Like x 8
                                • Agree Agree x 3
                                • toolmanmike
                                  toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                                  59,768
                                  47340
                                  Jan 18, 2006
                                  Iowa
                                  Local Time:
                                  3:48 AM
                                  Well said.
                                  • Agree Agree x 3
                                  • yellow rose
                                    28,824
                                    25246
                                    Jun 19, 2015
                                    Central Washington
                                    Local Time:
                                    1:48 AM
                                    Glad you found this. I was going to try and explain it, but no way can I do it like you do. And it wasn’t worth me jacking it up and then you needing to come back and correct me.
                                    A simple phone call would have cleared it up, but that’s too hard for way too many.
                                    • Like Like x 2
                                    • AndyF
                                      1,956
                                      2200
                                      Feb 23, 2009
                                      Oregon
                                      Local Time:
                                      1:48 AM
                                      But you aren't the OP. Far as I can tell, the OP doesn't need anything fancy. A set of used Isky nodulars would probably work just fine for what he is trying to do. If he can't find them then the best alternative on the market these days is the Comp steel rocker arms. One of the cars I help tune has a set of Comp steel rockers on a 505 big block with a fairly big solid roller. Engine makes 750 hp and the car runs 9's every weekend at the track. That is probably pushing it for Comps but they have lived okay for several years on that engine so they'll handle anything the OP needs.
                                      • Like Like x 4
                                      • Agree Agree x 1
