[WANTED] Rocker molding clips
I'm also looking for these clips. I wonder if the 1969 Coronet rocker clips work. They are available online. Does anyone know if they are the same?
Have you tried Mr G's? It's where i got the ones for my 69.
https://mrgusa.com/
Go to "Fasteners" and download the "clips" pdf's and see if there is one that looks the same then call them.
Thanks dano. I ordered some at 60 cents a piece. They look right. I'll see if they are the right ones when I have them in my hand. I'll post when I find out.
What part number did you order from mr g's.If you ordered fa468 its not a 2" molding clip
I did order FA468. My clips are for a 1968 Dart rocker (sill) molding. The small Plastic clips shown look exactly like the ones I need. I destroyed a few before I figure out how they work. We must be looking for different clips.
I think 69 barracuda may be the same but cant find them either
True but not many '69s were built with the moldings. Early Scamps use the same molding clip as a Duster (2" wide) but the Scamp is a longer wheel base so the molding itself is not interchangeable with a Duster. But if you are trying to locate used clips put Scamp on your list of cars to look out for.
this is the clip for the Duster 1 3/4" moulding.
the moulding has a blind bolt at the front that goes through the rocker and is captured by a nut inside the wheel well.
..with that tightened these could be made out of sheet stock just wide enough to slide on and catch the outside edges of the moulding along the rocker.About 7 or 8 pieces should do it.
