Rockers to buy...1.5 or 1.6?
dusterdoug
Tracy, CA
What would you do: Buy a cam with a little less lobe lift and put a 1.6 rocker on it, OR...stick with the bigger lobe lift and a 1.5 rocker?? This is for a combo that can only use about .590 lift with my springs. Any advantages either way???
Thanks!
I'd rather purcahse the cam with the ntended lift and a 1.5 rocker.
Sometimes, the 1.6 rocker can have a clearance issue.
