USAJon
Maryland U.S.A.
- Joined
- Nov 20, 2008
- Messages
- 722
- Reaction score
- 1
Mechanic Rodney Belice my old school racer bro.
Project: using a 1998 Jeep Cherokee limited 5.9 motor/rear
installing in a 1975 Scamp Tramp . was a stock 318 V8 race car.
He will run the factory fuel injecting/removing all the Jeep electrics, including dash. He has installed the dash after removing the factory Scamp dash, cut the steering wheel shaft and welding to the stock shaft.
put the Jeep rear 4:10 lock up, after removing all coil spring stuff, buying spring perches off summit, since there was no bolt holes for a pinion snubber he installed summit chrome traction bars. The rear has a factory aluminum center section factory .
