Roof rail stainless on 69 Cuda fastback
moparlee
64 Valiant
Joplin, Mo
What is the correct term for this...this car was taking apart not by me....and trying to figure out what the correct screws are. It's what the roof weather strip goes up into. There is flat like gasket that goes between it and the body.
Thanks in advance.
Roof rail is close enough, they look like these.
RT specialties may have them. I bought an entire kit that had them. Check with classic industries as well. E-bay is another good source.
Though not exactly an answer to your post, if you buy a catalog from Year One, it will have LOTS of Exploded View diagrams in it with the proper name of many parts (and some part numbers). The nominal charge for the catalog is offset by the coupon applicable to your first order they conveniently bury in the back of the catalog. By the time I found mine it was already expired.
FYI, if you have a good hardware store nearby with a big nut, bolt and screw department, you may be able to find some flat headed screws. They are hidden by the roof rail weather strip, so you won't see them.
Ya, been looking at YearOne and Classic Industries. Thanks again for your help everyone!
We don't really mind using something different....just was looking at length, size and size of head. What do you guys think....this is only place that I've seen actually list them.
R/T Specialties - Mopar Fasteners, Clips & Hardware
The customer has bought an exterior and interior screw kits from Classic Industries and of course they're not in there.
Lee
