OLFOOL
OLFOOL
Never noticed before but the J heads I have just bought, the exhaust valve once fitted I can rotate the valve when the locks are fitted, is this normal as I am quite new to small blocks. thanks.
I've never been convinced they ever really worked at all. As many burned exhaust valves as I've seen through the years that had rotators, you just caint prove it by me.Rotators work great but the problem is you have to run a short spring so it limits you to small cams. Mostly used on industrial engines.
the multi groove locks allow the valve to rotate freely i read this in an article the intake locks grip the valve , the exhaust do do not. take a lock and grip it, then rotate the valve, i've done that, just food for thought
I thought it was common for valves to rotate during operation.
Did I have that wrong?
I've never seen slant sixes do that and they all came with four groove locks on the exhaust with solid lifter cams up to 1982.Yep, multi groove locks touch each other when they are assembled so they don’t totally lock on the valve stem. It makes them rotate.
I know guys use that style lock with solid lifters but every time I’ve seen it done it beats the hell out of the valves and locks in pretty short order.
Hydraulic lifters don’t mind because you don’t have the lash beating on the lock.
You always post nonsense. Your wife told me so. lolNow that I posted what I did my foggy brain said all multigroove locks touch so the valves rotate but IIRC the two groove, square locks lock onto the valve and do not rotate.
Of course, I could go out to the shop and verify that by my doc and the warden (my wife) have banned me from the shop until I see the real heart doc.
Someone here should be able to verify that one way or the other so I’m not posting nonsense.
