Jonnylightening
Are there any downside to running Rotella 15w40 in my 408 magnum?
I was just reading on a few posts about it. Looking for something to run in it permanently. What weight would be preferred?If its for diesel, it has things you dont need or even want in some cases.
If it's all you have and it's a one time thing...it wont kill it.
It depends what bearing clearances the engine has and how it's going to be used.I was just reading on a few posts about it. Looking for something to run in it permanently. What weight would be preferred?
What kind climate do you live in?I was just reading on a few posts about it. Looking for something to run in it permanently. What weight would be preferred?
I can't remember the exact number but it was like .0025 ish. Going to be a street strip car, more strip thoughIt depends what bearing clearances the engine has and how it's going to be used.
Eventually I do want to run staffers. Just at the moment want to get it in and running. I live in PA so summers are anywhere from 60-90°What kind climate do you live in?
If its California, 20/50 or 30 covers most.
East coast, 10/30 or 30
I think Chrysler had it right with where the middle of the road was..30 wt.
You can technically run 5/20,30,40 etc...
Heat fades the psi as much as 15psi or so shown more at idle on the gauge. 20/50 was chosen as the general race weight because of it's good operating temp range protection aka viscosity sustainability from low to high rpms and film strength for momentary air pockets in the system, 'think pickup gets uncovered with g forces'
Me.. I run Schaefers superme 7000 20/50 para synthetic.
That's a little loose. 20w50 should work fineI can't remember the exact number but it was like .0025 ish. Going to be a street strip car, more strip though
Which Rotella? There's T3 (Dino), T4(Blended), and T5 (full synthetic).
With flat tappets, run the T3 (has zinc ZDDP additive). If you're running rollers, the blended or full syn will work just fine.
This ^^^^^^^^It depends what bearing clearances the engine has and how it's going to be used.
Yep, you're right- I was just shooting from memory, which is a crapshoot at my age...A little off. T4 is dino, T5 Blended. I've run T4 15w-40 with a bottle of zinc in the hot rods for years. Also put in my mowers and T5 in my Victory bike. I'm a fan. It takes diesel abuse to 10-15,000 miles without issue. It's certainly good enough for our little motors.
Check the current spec sheets and oil analysis (virgin and used) that people post on the web.
Many oils including the Rotella line were revised about 5 years ago.
This ^^^^^^^^
Here's what was posted in:
Oil Viscosity vs Bearing Clearance
and discussed in posts here
Valvoline VR-1 vs. Lucas Hot Rod oil
[Below is quoted from the thread linked above. I'm not a builder and in no position to say whether the are good guidelines based on my on observations and experience, but they appear to be.
For general use, its usually better to use a multi-grade.
Whatever W portion is in front will provide better lubrication when the oil is not fully warmed up than a straight grade. One they are at operating temperature, the viscosities are about the same. That said, 40 and 50 grades tend to have better high temperature, high shear performance.]
Multi-grades.
Some recommended rod bearing oil clearances for various oil viscosities:
.0015 to .0018 for 0W20 or 5W-20
.0020 to .0024 for 5W-30 or 10W30
.0025 to .0029 for 10W-40 or 15W40
.0030 to .0040 for 15W-50 or 20W-50
For main bearings:
.0015 to .0020 for 0W20 or 5W20
.0020 to .0025 for 5W-30 or 10W30
.0026 to .0030 for 10W-40 or 15W40
.0031 to .0041 for 15W-50 or 20W-50
Single Grades
Rod bearings with
.0015 to .0018 use 20
.002 to .0024 use 30
.0025 to .0029 use 40
.0030 to .004 use 50
For main bearings:
.0015 to .002 use 20
.002 to .0025 use 30
.0026 to .003 use 40
.0031 to .0041 use 50
After break-in, depending on how it was machined, probably best to use a conventional base stock for a few thousand miles.
One current option for a conventional oil with decent Zddp levels is "Ford Super Heavyduty" which meets FORD WSS-M2C171-F1
some specs here
PETROLEUM QUALITY INSTITUTE OF AMERICA TEST PROGRAM
The higher the spring pressures, the more concerned I'd be about the ZDDP.
800 ppm is pretty good.
For a cam that's somewhat radical, I personally prefer an oil more around 1200.
I tried to get the builder's view on that for my jeep's 360 and got a pretty vague answer. Figured it was best to assume the rings might need conventional. Stock cam, 0.30 over, just a rebuild.What I disagree with is it’s not 1985 anymore. A properly honed bore with modern rings will be ready for synthetic oil as soon as the cam is broke in. I’m all for leaving the brake in oil in longer than that. I leave it in for 700 miles or so and go straight to synthetic oil.
I'm not a big fan of using diesel in gas engine. Even Shell does not recommend it.
No reason to use a 15/40 in most vehicles either.
I had a Ford van with a 351 gasser . Bought it with 105k... Sold it with 485k. Tried Citgo 10w-30...used too much and the oil temp soared. Went to Mobil1 10w-30 after the first change.
I have 30w CenPeCo for my race motor. I use a single grade for the alky motor.
Does anyone know if Rotella or other diesel oils still have zinc? I was told 2 or 3 yrs ago that Rotella doesn't have it anymore.True or false?
