Rough idle issue
Slant 6 Engines
  1. briwill70
    briwill70 Well-Known Member
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    9:48 PM
    Trying to diagnose rough idle on new engine. New HEI ignition, tested wires, NGK ZFR5N plugs, Weber 38 adjusted to best lean idle and timing at initial +15 degrees. Also snugged down all intake bolts and does not appear to have any leaks. Runs and accelerates great but stumbles a bit when idling. Really bad in gear.
    Has a Oregon 2106 cam, adjusted lash to .015 IN/EX per cam card while on the stand. Maybe too tight? Other thoughts?
  2. dano
    dano Evil Handy Man
    3,333
    1204
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    9:48 PM
    Too lean at idle could be your issue. Have you tried adding a little fuel to see if it changes anything? Do you have a wide band to measure the o2?
    Today's fuel lights off way fast and is designed for fuel injection, so in this heat (cooler than it has been) you might be getting some vapor lock for bowl boil.
    Other thoughts, do you have vacuum advance hooked up? If so is it to a ported vacuum source or full vacuum? It should be connected to ported. What is the mechanical advance in the distributor?
  3. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    9:48 PM
    I don't have a O2 sensor but I don't think fuel is the issue. Sounds like a miss to me. Dist hooked to ported vacuum and is a new old stock electronic unit. Will probably check plugs, do compression check and adjust valves next to rule out any mechanical issues.
  4. Rmoore
    Rmoore Well-Known Member
    419
    253
    Nov 14, 2018
    Gun Barrel City, Texas
    Local Time:
    11:48 PM
    Think I would take some brake clean and spray all the vacuum hoses and fittings !! Base of carb or weber what ever you have , and intake manifold !! You will find your vacuum leak if you have one !
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      19,239
      7124
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      11:48 PM
      Isolate the cylinder
    • teringer
      teringer ase master hall of fame FABO Gold Member
      846
      199
      Feb 22, 2011
      kenly nc
      Local Time:
      11:48 PM
      put a shop towel ( cloth) on top of carb and see if it idles better if it does its lean
      • Like Like x 2
      • j par
        j par Well-hung Member
        24,688
        12975
        Jul 2, 2014
        Portland Oregon
        Local Time:
        9:48 PM
        When you say you did this "on stand"?..
        Was this on a engine stand or an engine run stand? As in did you do it while the engine was hot? Because that's what your cam card is calling for when the engine is hot and yes it changes...
        What does an Oregon 2016 cam specs consist of? So I don't have to go find it I assume this is a slant six?...
      • slantsixdan
        slantsixdan =..=
        6,737
        1909
        Jan 7, 2007
        Vancouver BC
        Local Time:
        9:48 PM
        The Oregon 2106 cam is the Dutra RV10 (vs. the 2106R, which is the RV10-RDP). It's an optimised version of the MP 243 cam (which was 244°/244°/28°/0.436"). Nowhere near a big enough cam to cause rough idle; there's something the matter here and I'm guessing it'll be found in the carburetion department, but you might try backing off your valve adjustments to 0.020"/0.020" (hot and running per valve adjustment procedure) and see if it does anything for your rough idle. If not, it's easy enough to change back.
        15° BTDC is a lot of initial timing—could easily be too much. Some time and effort or money invested in dialling-in your advance curves so everything's happy at 5° to 7° BTDC will pay back handsomely. Talk to DusterIdiot over on slantsix.org if you're not up for recurving you distributor on your own.
        • Like Like x 2
        • briwill70
          111
          30
          Feb 2, 2020
          Portland, Oregon
          Local Time:
          9:48 PM
          Thanks. I drove the car around last night to get it hot and re-adjusted the valves. Was surprised that my cold on engine stand adjustment was pretty much dead-on at .015. I opened it up to .016 and drove again. I can now hear the slightest chatter from the rockers. Set the lean best idle again and it seems to be smoother now. Will drive it for a couple days and maybe open up to .018 to see if that further changes things. I'm open to recurving the distributor. It's a new old stock from OCPNW. Just trying to get the old girl smoothed out first.
        • halifaxhops
          halifaxhops It's going to get stupid around here! FABO Gold Member
          61,008
          29566
          Jan 20, 2014
          CENTRURAL, PA
          Local Time:
          12:48 AM
          Find some one that still has a scope and can read it it will definitely let you know what the ignition is doing.
        • briwill70
          111
          30
          Feb 2, 2020
          Portland, Oregon
          Local Time:
          9:48 PM
          Interesting new development. I saw some moisture around the block off plate on my Super six intake. Removed the block off plate and some fuel dribbled out. Was kinda wondering when I installed if fuel would pool in this area through the hole in the intake. Has anyone had this issue? Also possible this was a vacuum leak but kinda doubt it since it was holding fuel.
        • volaredon
          volaredon Well-Known Member
          181
          25
          Feb 28, 2010
          IL
          Local Time:
          11:48 PM
          I have a super 6 intake that I am getting ready to put it on to my son's truck, and the port that you show, I tapped out under the carb and put in a pipe plug , with red loctite for insurance.
          My 85 came to me with no manifolds under the hood/ but a pre egr intake and exhaust manifold in the bed. Just a 1 BBL for now but good enough to verify that I have a running engine. I have a super 6 setup for it too.
