RPM Air Gap with AFB and stock air cleaner to hood clearance measurements
DionR
Spokane, WA
In another thread I mentioned that I have an Edelbrock RPM Air Gap intake with a 1/2" carb spacer, AFB carb and a '72 trap door air cleaner and didn't have clearance issues with my hood. This prompted a request to take some measurements to see how much clearance there was. Instead of cluttering up that thread, I figured I would start a new one.
Gotta say, this was kind of a pain in the ***. Partly because I expected it to be kind of a slam dunk with multiple little balls of playdo and not much clearance. Clearances ended up being pretty large so I ended up with playdo columns and only a couple at a time.
Here was my first attempt. No contact. ???
Here is my second attempt, still no contact. WTH?
Started making contact after that. Here is a shot of all the clearances along with the "reference point" numbers. The circles are where the playdo made contact. I started putting a little piece of tape on top of the column so I could see better, then started putting a number on the tape with a number next to the column to make it easier. That made it much easier to keep track of things.
Here are points, 1 and 2. Playdo on the far side didn't make contact that I could tell.
Points 3 and 4. Playdo column on the far side didn't make contact that I could tell.
Point 5. Not really sure how, but seems I lost the point marked as "4" in this picture.
Points 6-9. I started putting a piece of tape with a number on the hood at the contact point, which is when I realized it would be smarter to just put the tape on the column before I closed the hood.
Points 10 and 11. This is where I started to get a little smarter and put the number next to the column as well as a piece of tape on top of the column.
Last reference point.
To be clear, this is a Hughes intake based on the RPM AirGap. Don't think it is any shorter than the standard AG intake, but I could be wrong.
Other points of data are this is using a '73+ spool mount k-frame and stock motor mounts.
