mattmatthew
^_^
Recently did a front end rebuild and a disc brake conversion to the single piston floating style calipers/rotors. Used a pair of remanufactured calipers, and the rotors are returned with plenty of meat on them. Bled them a few months ago, but never drove it. The other day took it on a road test a few times around the block and there was this really loud rubbing sound coming from the front passenger wheel drivers side wheel was ok, braking was good, overall.
Today I removed the front wheel to investigate sources of the noise, and found that the pads were very slightly rubbing against the rotors, even with the piston fully retracted.
Is this normal? I'd guess that aftermarket pads combined with reman calipers and used junkyard rotors might have slight incompatibilities. Is it safe to sand down the pads slightly to remove the rubbing sound? The rotors turn by hand, but I can still hear the rubbing noise. Or is it something that will go away eventually by driving the car?
Also, what is the proper bedding technique for the pads?
