Mr_Sancho1324
Active Member
- Joined
- May 7, 2010
- Messages
- 33
- Reaction score
- 0
Hi guys. So I'm running hot again. Everything was good until I replaced my carb. Here is my setup
318
Aluminum radiator
Distiller water with water wetter
Electric fan
160 thermostat
High performance water pump
Msd coil
1850s 4 barrel Holley carb with secondary vacuums with 65 jets
It's seems as if I'm running too lean. I purchased the larger jets and as thinking of re-jetting it with the 69 size jets.
I also checked my plugs and they are white so definitely running hot
My timing was just adjusted to 10 degrees.
Any suggestions?
Ps I live in Vegas and it's 100+ degrees and I'm running around 210...that's the highest.
Any help is greatly appreciated.
318
Aluminum radiator
Electric fan
160 thermostat
Msd coil
Any suggestions?
