moparnate52
Member
the car will run with the key in the start position, then when its out it dies. it has stock ignition on a 72 dart 318
this should be a sticky. I guarantee I have seen this same question 50 times. There is a search feature here that would have found the answer to this.just so ya know.
wheres the risistor located?
Neutral saftey switch can heave the same effect I believe. Run a jumper to the spot on your relay and ground it out. Car would run if I kept my hand on the start position but would die after realeasing. Just a thought
choke not opening all the way?
