SB 8 bolt crank need flexplate
Belvedere2
Active Member
MA
Hi. Looking for suggestions on a flexplate. Engine is a SB mini stroker; 3.79 crank/ 8 bolt, making 550hp. Convertor is a Dynamic 9.5" street/strip. 727 trans. Mainly drive it on the street but expect to make a pass or two a year down the track. Thanks!
Mopar 8 bolt pattern are all the same ,,,,,Hemi flexplate is perfect for you .
Factory Mopar is hard to beat !
Tommy
Thanks. Would that Dynamic be considered a 10" even though they call it a 9.5? I'd measure it but its presently in the car.
