SB Cast Iron Exhaust Manifolds
Tony Fields
That's How I Roll
Legendary Member
Columbus, Indiana 47201
I will be using cast iron manifolds on my 360 going into my '67 Cuda.
Here are the casting numbers:
Pass. side 3418623
Dr. side 3614395
My Mopar dot com lists these manifolds for the 1971-73 Dart 340's
My question is this:
Why would the discharge port be smaller on the driver's side. Did the factory
use two different size "ball flanges" on the front pipes? Any info would be
appreciated.
Thanks
I show the #3614395 as a '73-'74 A 318 manifold which would account for the smaller outlet. The #3148623 shows as a '71-'73 ABE 340 manifold.
Chuck
Chuck
Thanks Chuck
One more question
Will casting number 3418621-1 fit on the drivers side of a 1967 Barracuda?
Car is non power brakes and non power steering
Tony Fields said:
Thanks Chuck
One more question
I show that one as a '71 BCE 340-360 manifold, being auto makers like to share as many parts for saving costs if it would have worked they probably would have used it instead of making a spedial left manifold for the A body.
The '72-'74 A 340-360 manifold you are looking for is a #3614368 this one is the match to your #3419623. Or the '68-'71 A 340 #2863553
But I hear these are quite pricey when people sell them.
I have heard of people using the Dakota manifolds on the A-bodies and there has been a thread with pictures of it on this site. I will see if I can find it.
Found it
http://www.geocities.com/lars_an_artist/durango.html
Chuck
