440marv Well-Known Member Joined Oct 7, 2008 Messages 50 Reaction score 0 Location portland oregon Feb 27, 2011 #1 is the oil pump gasket needed or a good idea on a sb?
M MRL Performance Well-Known Member Joined Jan 21, 2011 Messages 1,929 Reaction score 321 Location here Feb 27, 2011 #2 It depends on the pump and main cap surface. I put mine on the mill and clean them up so they are flat, and do not use a gasket. Some are pretty bad, and if you dont want to put them on a mill, then yes use the gasket DRY no RTV
440marv Well-Known Member Joined Oct 7, 2008 Messages 50 Reaction score 0 Location portland oregon Feb 27, 2011 #3 thanks
