[FOR SALE] SB solid roller cams
Gearhed73
So.Cal
Two solid roller small block cams
First is a custom ground comp solid roller that has never been ran
Second is a lunati voodoo that has about 5k on it
Cams located in HB
$325 for comp
$250 for lunati
Shipping $25 per cam in lower 48
Specs on lunati
Voodoo Solid Roller Cam. Good cam for high performance street or mild strip applications. Needs 2500-3000 RPM stall converter or 4-speed transmission, headers, 9.5:1+ compression ratio and 3.73+ gearing. Rough idle.; Advertised Duration (Int/Exh): 267/273; Duration @ .050 (Int/Exh): 237/243; Gross Valve Lift (Int/Exh): .566/.578; LSA/ICL: 110/106; Valve Lash (Int/Exh): 016/016; RPM Range: 2500-6600; Includes: Ca
