[FOR SALE] Sb timing cover
dgibby
Texas
stripped and primed with ceramic engine primer.
$55.00 shipped within USA.
Small block 1970 and up or small block with aluminum water pump (pass side lower hose)
yes, the tipoff is it takes the large seal that goes in from the front. If needed for your radiator nipple you can use the early pump & still see the marks if you aim your light just right but it is easier to (if using early pump) to remark the dampener on the pass side & make a pointer for the pass side
