SBP 14" Cragar SS mags
Mopar Mechanical Parts For Sale
Thread Status:
  1. EL5DEMON340
    EL5DEMON340 Well-Known Member
    4,269
    157
    Feb 6, 2009
    Aurora,IL
    Local Time:
    7:16 AM
    Contact Seller
    These have been on the car since at least 1973, they are in driver condition, they have small pits and some lifting/cracking in the chrome, outer ring, i painted the spokes in krylon metalic black, center caps have pitting, one front rim center cap has been epoxied to the rim do to the lip that retains it being damaged, you would have to pop it out to balance and re glue, i thin they are 6" wide, the rears are reverse offset so the back space is i think about 2.5", i dont think they will work on darts unless you roll the wheel well lip, tires have about 9K fronts about 80% thread rears are worn maybe can get a summer out of them. front are 215/60 bfg's rears are 245/60 bfg's car rode fine with no shakes or vibration. comes with lugs and washers. even with the chrome issues i still get a lot of complements on the look of them. WILL ONLY SHIP IF YOU DO THE LEG WORK AND SET IT UP. $250 obo. located in Aurora, IL PM for more detailes.
  2. ozley_2000
    ozley_2000 Active Member
    31
    0
    Feb 24, 2010
    Coarsegold, ca
    Local Time:
    4:16 AM
    Are these the small bolt pattern or 5x4.5?
  3. 6pk2goDemon
    6pk2goDemon Mopar Mod Staff Member FABO Gold Member
    11,277
    2579
    Mar 1, 2008
    Arizona
    Local Time:
    4:16 AM
    5x4 small bolt from ad title is what I'm reading :read2:
    The Cragars still look great as well as the stance EL5. What wheels are next? Good luck w/ the sale :cheers:
  4. EL5DEMON340
    4,269
    157
    Feb 6, 2009
    Aurora,IL
    Local Time:
    7:16 AM
    Ralleys 14's front, 15's rear, 215/75 front, 275/60's nitto drag radials rear, also have changed the look of the engine, and scored some original buckets with mint covers, 2 miles away !!!
Thread Status:
