[SOLD] SBP Front disc brake conversion
lee01
Cantley, Qc, Canada
So i'm starting to sell some parts that I gathered for my Duster.
This kit is setup to change my 9'' front drum to GM disc on my 71 Duster.
but will fit other:
[FONT=&quot]'' A '' body 1965-72 10”
'' A '' body 1960-72 9” [/FONT]
Here's what I have for this kit
Everything is new (master rebuilt)
2x Rotors
2x GM type calipers
1x set of brake pads
2x Brake hose
1x Correct Master cylinder (non power and Disc/drum)
2x Scarbird Adaptor plate/bracket
1x SSBC proporting valve
With this kit, you keep your lower ball joint and small bolt pattern.
You need to redrill the rotor to the correct pattern, I have the pattern sheet.
Also the caliper may need a little grinding depending on your wheels.
Only thing that is missing is longer stud.
I painted the master cylinder cast color so it won't rust once installed.
Looking for 450$ plus the ride....and its a heavy box and from Canada.
You will pay actual shipping depending on your postal code or zip code.
