[SOLD] SBP Kelsey Hayes Disc Brakes
Mopar Mechanical Parts For Sale
Thread Status:
  1. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,770
    3313
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:27 PM
    Contact Seller
    Got a set of SBP Kelsey Hayes disc brakes that came off a friend's running, driving car (64 Dart). Included is the spindles, calipers, rotors and dust shields - everything pictured. This should fit from 63 through 72 when using the small ball joint UCA. If disassembled into component parts, they ought to fit in a large flat rate box - about $15 per box to anywhere there's a US ZIP Code. Otherwise actually shipping from 22657. Asking $400 plus the ride. Also got a set of 73-76 discs in another thread.
  2. 65 Dartman
    11,770
    3313
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:27 PM
    Nobody needs a set of KH disc brakes 5 on 4 SBP ready to bolt on, bleed and go? I'm surprised!
  3. senior60
    senior60 Member
    20
    0
    Oct 28, 2009
    Local Time:
    8:27 PM
    Do you still have the sbp disc brake set up. Thanks
  4. 65 Dartman
    11,770
    3313
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:27 PM
    I tried to fit one of these bolted together assemblies in a large flat rate box and it just wasn't gonna go :(. I have 2 complete KH disc set-ups (but all separated) for other projects and and looks like the rotors & dust shields will go in one large flat rate box and the calipers, spindles & hardware in another :-D: So looks like shipping will be $29 to any ZIP Code
  5. senior60
    senior60 Member
    20
    0
    Oct 28, 2009
    Local Time:
    8:27 PM
    How much meat is left on the rotors. What size are the rotors. Do you know when the calipers were rebuilt. Thanks
  6. 65 Dartman
    11,770
    3313
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:27 PM
    What I am selling I bought from a friend who removed them from his 64 Dart when he decided to go LBP. I know he had the calipers rebuilt so I will have to check with him on that. I will have to take the rotors to a machine shop as I have no way of measuring the thickness other than visually comparing them to the NOS rotors I have.
    I do have 2 sets of rebuilt calipers (as well as the NOS rotors) and they will be used on my Barracuda and Valiant vert.
Thread Status:
