SBP Rims/Tires, Carter Carbs
ConValiant64
Brigantine, NJ
I've got four steel 5x4 (sbp) rims with mounted and balanced Cooper tires hardly used in size 185x65x14. Two of the rims are Rallys.
Also have two Carter Thermo Quad carburetors in good working condition. Just removed one from car in favor of a Holley double pumper. Stamp numbers upon request.
Asking $200 for all four rims/tires and $200 for both carburetors, but would rather trade/partial trade for small block headers that fit an early A body (ie 1964 Valiant), or an 8 3/4 bolt in rear, A833 tranny, etc. Will consider all Mopar related trades.
FYI-I live in South Jersey.
Look at the drivers rear base plate on the backside for the stamped in numbers as pictur below and smear d in “White Out.”
Those are the important 4 numbers to list. Everything else is not so important.
Rumblefish,
Smeared some White Out on the stampings. I'd be happy to send you some pics. Unfortunately, unable to download anything on this site-my computer crashes. Can you send me a cell phone or e-mail address?
Send carb pictures as well. All 4 sides of each carb in different e mails.
I’ll start up a new thread.
I can not accurately get the numbers ether. In general, though not exactly accurate, TQ’s are commonly rated @ 800cfm for the small primary and 850 for the large primary. It is a commonly excepted rating. There is a thread here by a legendary member with actual flow rates.
737 & 787 cfm.
Carter Thermoquads ~ 'More General Information'
