Scratched Rod Journal
69Chrgr
Charger/Cuda
Midlothian, Texas
Dam, I think I lightly scratched a rod journal taking the rod in and out for side clearance. My own fault. Am I screwed? Any fix, or do I take the crank back out. I had so much accomplished, now this sucks! :sad:
I think you can put rubber hose over the rod studs when you pop them in and out and it will save those journals.
Depends how deep the scratch is. In all likely hood you can dress it starting with some 500 grid emery and finishing with 700. You may not have to get the scratch totally out but you diffeniately want to get rid of any high spots around the boundary of the scratch otherwise it'll tear up a bearing.
Terry
