Guys, I have a set of Sealed power pistons (H405CP) in my 360 motor. To add a little more compression i am about to fit a Mopar Performance head gasket .027" compressed thickness.
I need to know If I have sufficient piston to head/valve clearence. I've read elsewhere on this site that these pistons sit approx..080" down the hole. I put a feeler gauge across the top of my piston at TDC and thre is .025" to the deck. Should I be concerned about clearance?
