[WANTED] Seat belt bolts
Roadart
Escalon ca.
Hope to find the four(4) bolts that hold the front seat belts to the floor. Need them for a 72 dart. Two go on the side(L&R) and two go on the hump. I have the belts. If you have the shoulder harness that mounts to the roof panel I could use that also,but will be happy with the bolts.
I have a lot of seat belt bolts I’ve removed from various MOPARS. There are two different lengths. And some use a spacer to take for unneeded length. $10 plus shipping for the set of 4 if I have what you need
The four I need are 7/16"x20 threadswith 1/2" spacer at the top.It takes a T-45 torkshead to tighten/loosen. The other two are also 7/16"x20 with a 3/16" spacer at top.It takes a 13/16" socket or wrench to tighten /loosen. If you have these,let me know how you want payment.
Ok I’ll check on that this weekend.
Nope, sorry. I don’t have those.
Let me check later today after work.I know I have some 13/16" head type, not sure of torx though.....
Dave
As long as they fit .I don't care what head shape etc. Thanks
I have some in this lot of bolts(lower left). Hex , not torx.
As long as the bolts hold the belt hardware I do not care what head is on them
