seat belt options
rebeldart
North FL
I've got buckets out of another (brand) car - need seat belts/shoulder harnesses by law - starting from scratch, any advise (I'm actually missing the front buckles ("female") only ?
If you want to stay all Mopar, find a serviceable set from a pre 94 truck or any 76+ van. The van female side might be a little short if you were using bench seats, but should be no problem with buckets.
F/M/J bodies are a good source of belts other than black. On some of these, you'll need a TORX socket to remove the bolt. I think it may be a T-45, but don't hold me to the size. My Intermittent Alzheimer's is acting up again. Gotta go, the guys in white coats are heading this way..................
