Seat Belts
Jason96R
Ohio
Does anyone know if 73+ seatbelts will work on a 69 cuda. They are the fronts with tensionors. Any help would be appreciated, seeing if will buy them from someone on this site if that helps. Thank you
Jason Foster
The 1973 lap belts with the separate shoulder belts will bolt in - floor mounting locations are even the same. But later ('75 & '76 I think ??) belts were of a more modern lap/shoulderbelt combined design that would require your car to have roof mounting points that just are not there.
Has anybody installed these seat belts on a 67-69 Barracuda? How do they look/function?
I have a set of rear belts I'll sell cheap if anyone needs them.
Thanks 74 Sport looks like that would be a much better setup. Fastbackcuda now that I can finally login who/where did you get that fan shroud and how much did it cost? Thank you.
The fan shroud came with the car so it cost me $3000 :mrgreen:
Its actually missing a chunk from the bottom. They show up on Moparts once and awhile for rediculous money.
fastback cuda what colour are your rear belts? Figure they outta be the same as my 71' Duster
They were black but they have started to turn green from the sun. :scratch:
