Selecting the most accurately dated AVS carb casting
Fuel and Air Systems
  1. Rocket
    Rocket FABO Gold Member FABO Gold Member
    2,081
    310
    Apr 22, 2005
    Manchester, CT
    Local Time:
    7:23 AM
    I am in the process of restoring my 69 Barracuda. I am looking for a carb core to rebuild. How far in advance of a mid March 1969 vehicle production date should I look for in the month cast into carb? What would be a reasonable number of months in advance if I want to be fairly accurate?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    55,975
    42270
    Jan 18, 2006
    Iowa
    Local Time:
    1:23 AM
    2-3 is good.
  3. A56
    A56 MoParAffliction FABO Gold Member
    2,963
    4883
    Jun 24, 2014
    South of the Mason-Dixon Line
    Local Time:
    1:23 AM
  4. A56
    2,963
    4883
    Jun 24, 2014
    Local Time:
    1:23 AM
    My fender tag build date is 2/26/69, my carb is an A9 (Jan. 69) the engine cast date is 12/10/68, body stamp date is 1/30/69
    • Like Like x 1
    • toolmanmike
      55,975
      42270
      Jan 18, 2006
      Iowa
      Local Time:
      1:23 AM
      Great comparison. Production dates are fun to study. The Carbs were made at Carter and probably warehoused there for a time until they were sent to Mopar's warehouse where they were warehoused until they ended up on an engine. That engine was warehoused until it meets up with the rest of the car. You can see the timeline there.
      • Like Like x 1
      • Rocket
        2,081
        310
        Apr 22, 2005
        Manchester, CT
        Local Time:
        7:23 AM
        Great information.
        Thanks everyone
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        18,837
        3241
        Aug 7, 2005
        92201
        Local Time:
        11:23 PM
        As long as it's prior to the build date in that model year, nobody could say anything regarding the date.
        You could have a carb on it that was dated sept 68 as long as it's the correct numbered carb. General observations in most parts is 2-4 months prior. "Just in time" inventory procedures were not in use back then. I've seen cars that had a SPD that was 3 weeks before the engine was built... yeah, that doesn't exactly jive.
        The SPD is only a scheduled production date, not the actual.
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        17,747
        5549
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        1:23 AM
        I think I have a B9 4612SA. If that will help u out. Kim
      • Rocket
        2,081
        310
        Apr 22, 2005
        Manchester, CT
        Local Time:
        7:23 AM
        That is a good date however I need a 4611S.
        thank you
      • toolmanmike
        55,975
        42270
        Jan 18, 2006
        Iowa
        Local Time:
        1:23 AM
        Have you started a want ad here yet? Maybe someone has one for you.
