Sirsmiley9
I need to know where the sensor locations are for the 360 magnum, and also where can i get plates to block them
What are you trying to do?
The magnum has a crank sensor on the back of the block that doesn't require being "blocked". The cam sensor is in the distributor. The throttle body has the TPS, IAC, and MAP sensors. The IAT is in the intake manifold. Coolant temp is in the intake manifold. That's all that I can think of on a factory magnum EFI setup.
My Magnum has a temp sensor in the passenger side of the block under the manifold.
I just left it in there unplugged, and used an intake temp sensor for an aftermarket gauge.
The only block off plate used is the LA style timing cover fuel pump mounting point.
What year/model? I've worked on and swapped a bunch of 5.2 and 5.9 magnums. I've never ran across a sensor like you've mentioned. But mopar has done some very odd stuff!
Knock sensor...I did a quick image search but can't find a pic of it. (non of them had it)
It is a single wire connection that has a pin in the center and had a squeeze to release type end on it.
I know I'm not confusing it with another motor because I just saw it again when I pulled to header on that side to fix a leak in a tube.
Knock sensor...
Makes sense.
I thought that might be it, but wasn't using it anyway so it wasn't important until it came up here.
Thanks.
I have never heard of or read about a knock sensor on a magnum. I'm currently running a Holley EFI on my 5.9 magnum. Knock detection would be a GREAT thing to have.
Which Holley system are you running? I'm looking hard at the new Terminator X Stealth. would love to hear you experience with what you have.
Holley Sniper is what I'm running. I would have spent a bunch more $$ for a Holley EFI with spark/knock control.
