Oct 3, 2010 #1 340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va just wondering, cause my numbers matching 340 has a build date of 8/29/71, and has a forged crank in it. would/could it still be a low compression engine? thanks to all for the help
Oct 3, 2010 #2 EL5DEMON340 Well-Known Member Joined Feb 6, 2009 Messages 4,256 Reaction score 600 Location Aurora,IL low compression, is that the number cast in the side of the block or the date that is stamped under the driver side head?
Oct 3, 2010 #3 Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,414 Reaction score 5,314 Location PA Post the full set of numbers on the front of the block right below the drivers side head surface.
Oct 3, 2010 #4 C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 20,325 Reaction score 8,494 Location 92201 and the VIN.
Oct 3, 2010 #5 340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va EL5DEMON340 said: low compression, is that the number cast in the side of the block or the date that is stamped under the driver side head? Click to expand... it is the number on the passenger side of the block, i think below the freeze plugs. what would the point of posting the vin help?
Oct 3, 2010 #6 EL5DEMON340 Well-Known Member Joined Feb 6, 2009 Messages 4,256 Reaction score 600 Location Aurora,IL side of the block is casting date, so it most likely was assembled 30 to 60 days later, making it a early to mid year 72 engine, 99.9% low comp.
Oct 3, 2010 #7 340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va ok, thanks for the info
Oct 3, 2010 #8 Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,414 Reaction score 5,314 Location PA The number I requested contains some of the actual build details.
