[SOLD] Set of 5 UEM ICON stroker pistons. .020 over 340 or a .060 over 360 LA using a 4.00” stroker crank
physixx
Edison, NJ
I have for sale a set of 5 UEM ICON stroker pistons and corresponding pins for either a .020 over 340 or a .060 over 360 LA using a 4.00” stroker crank. They are the flat top design with 2 valve reliefs, are forged aluminum and are the full floating connecting rod design. These pistons are used but in really good shape. The skirts do show some wear but again, they are used so will show the wear. The skirts aren’t collapsed and the tops are very clean. The ICON P/N is IC744-060.
ICON IC744.060 ICON Premium Forged Pistons | Summit Racing
They have 1/16”, 1/16”, 3/16” ring grooves and came out of a 1978 360 engine from cylinder # 1, 2, 3, 4, and 7. These would be great for a budget stroker build. I would like to get $60.00 for all five with the pins and pin retainers plus the shipping.
Ken
Edison, NJ
I wonder if i buy two more to match the set put in 340 ? 4 inch stroke crank and nice 2.02 J i plan to run i am not interested alumin heads.
Absolutely. Just get the ones that you need for the right cylinders so that the valve reliefs will be correct.
