moturbopar
Hi all I have a set of 10 year old never run stock style dished cast .030 360 pistons. Comes with a set of recond rods attached and new moly rings. The only problem is the assembly lube is 10 years old and like glue and will take some scrubing with a rag and brake parts cleaner or similar to get off:wack:. 1 piston is off of rod, can reinstall if wanted. Would be good for someone on a tight budget
$40 obo
$40 obo
