I have a set of 5 on 4" small bolt pattern rally wheels with new BF Goodrich "Radial T/A" 225/60/14 tires mounted, balanced, and ready to run. I am changing direction to larger bolt pattern and can't use them. The wheels are 14" x 7" with 3.75" backspacing taken from the outside of the lip to the mounting flange. They have been stored inside out of the weather, and the tires are in new condition.
The wheels look to be in great condition and have typical paint blemishes like chips that someone before me painted over. One wheel has a stud hole that is chewed up from what looks like someone removing a seized lug bolt, but a lug nut registers fine, and the area can be built back up with weld and ground smooth again if desired. The center caps and beauty rings have blemishes and are driver quality or candidates for restoration. Two caps are polished, and two are rough cast. I have an extra beauty ring that goes with the set.
I'm asking $1,000 obo for the set. I prefer local pickup near Denver, Colorado, but I am happy to drop them off at a nearby UPS, Fedex, or Fastenal. The buyer will be responsible for calling the store to make all the arrangements for packaging and shipping. My closest Fastenal is listed as distribution center, so the buyer will have to confirm they can process shipments. Otherwise, the nearest Fastenal store not listed as a distribution center is about a 2-hour round trip from me. I can deliver the set there for additional gas/time compensation.
Please reply with questions or private message me if you're interested. Thanks.
