TheLetterJ
Member
I'm currently in the middle of rebuilding a spare 742 case 8 3/4 for drag strip use. I was torn between going with a spool or rebuilding the already installed (and well used) Suregrip and was looking for some opinions of those that have been there, done that, with what I'm currently considering. I have a new clutch pack from Dr. Diff, as well as a stack of new/used discs/plates at my disposal. Instead of using the specified thinner flat plates on each side, would using thick plates (making all plates the same thickess) in their place lock up the diff somewhat like a spool?
It would seem to me that so long as the case halves fully seat with each other, and it looks like they will, this should work? Driveability traits of a spool aside, any reason NOT to do this? I'd just hate to get it all back together rebuilt as stock just to find that I can still break a single tire loose on an unprep'd surface.
