1. Cuda65Steve
    Cuda65Steve Member
    20
    14
    Feb 18, 2018
    Islip ny
    Local Time:
    6:29 AM
    What's a reasonable shave on a 225 head? Looking for a slight bump in compression.
    Gonna have a 2bbl into stock exhaust manifold and a 2.5" flowmaster.
  2. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    16,110
    5323
    May 13, 2010
    Grand Tetons
    Local Time:
    5:29 AM
    According to mopar performance you can go up to .110" no joke. I would shorten the head bolts with that so they dont bottom out before you hit proper torque and gasket squeeze.
    • Like Like x 1
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      60,933
      32652
      Jun 7, 2010
      Georgia
      Local Time:
      6:29 AM
      I just had a 170 head milled .100. Took it without lookin back. I think @Charrlie_S has "accidentally" done one like .125". lol
      • Like Like x 1
      • Charrlie_S
        Charrlie_S Well-Known Member
        2,902
        740
        Oct 17, 2005
        Silver Springs, FL
        Local Time:
        6:29 AM
        You really need to determine the use of the vehicle, and what octane fuel you can live with. Decide what CR will get you there, then make measurements to determine how much to mill. You can't run 9.5 CR, with a stock cam, and stock dist curve, on 87 octane.
        Not a major issue on the 198/225, but should ALWAYS check piston to valve clearance on a 170.
        There are some builders who have milled he block .100 and angle milled the head .100 on one side, and .200 on the other side. Not for the faint of heart.
        • Like Like x 3
        • Charrlie_S
          2,902
          740
          Oct 17, 2005
          Silver Springs, FL
          Local Time:
          6:29 AM
          Not necessary to shorten the bolts. Clean the threads in the block, and use lubricated hardened washers, under the head of the bolt. Thread engagement will be close to the same, and will have better clamping force.
          • Like Like x 1
          • Agree Agree x 1
          • moparmat2000
            16,110
            5323
            May 13, 2010
            Grand Tetons
            Local Time:
            5:29 AM
            I beg to differ. I had a 69 dart with a 225. Bought this thing with a badly warped head. It took .100" to make it flat. I chased out all the threads in the block and blew em out with compressed air, cleaned the bolt threads on a wire wheel on a bench grinder. Then on installation, i installed the bolts with a small amount of oil on the threads to effect a proper torque. This engine popped 2 head gaskets in a short period of time after that. Ended up having a machine shop buddy of mine knock 1/8" off the ends of the bolts before I installed head gasket #3.
            After that, I had no head gasket problems. What was happening was The bolts were bottoming out and providing barely enough clamping force, and the gasket would be fine for a very short period of time, then it would pop. Maybe my block was not drilled and tapped deep enough from the factory, but removing a bit from the threaded end of all the head bolts seemed to correct the issue with as much as I had to have milled off the head. BTW that .100" milled seemed to give her a little more getup and go as much as one can get from a stock 1 barrel slant sux.
            • Like Like x 2
            • Charrlie_S
              2,902
              740
              Oct 17, 2005
              Silver Springs, FL
              Local Time:
              6:29 AM
              That is why you use the washers. They are close to the same thickness, as the metal shaved from the head. So the thread engagement stays the same.
              • Agree Agree x 3
              • Like Like x 1
              • moparmat2000
                16,110
                5323
                May 13, 2010
                Grand Tetons
                Local Time:
                5:29 AM
                I used whatever was there. Add washer, or shorten bolt threaded end by a small amount, still the same difference. End result was still the same. It quit popping headgaskets.
                • Agree Agree x 2
                • Cuda65Steve
                  Cuda65Steve Member
                  20
                  14
                  Feb 18, 2018
                  Islip ny
                  Local Time:
                  6:29 AM
                  You've got nitros and turbo Slants...….None have a shaved head???
                • Charrlie_S
                  2,902
                  740
                  Oct 17, 2005
                  Silver Springs, FL
                  Local Time:
                  6:29 AM
                  NA 170 street motor has 9.5 CR (which is too high for the cam I am running. Had to do a lot of distributor work).
                  170 turbo motor has head with just a "cleanup/truing" cut and a .080 thick head gasket (7.9 CR)
                  Nitrous 170 and 225 motors both have approx .125 milled off the head (38cc chambers)
                  • Thanks! Thanks! x 1
                  • Killer6
                    Killer6 Well-Known Member
                    2,430
                    808
                    Mar 9, 2015
                    PA
                    Local Time:
                    5:29 AM
                    That is sorta/kinda true, but besides not having to "machine" the end off by a pro, or grinding on ones own & cleaning up the threads, a set of lubed & hardened washers results in better/more even torque on the bolts w/o all the grinding....................
                    • Agree Agree x 2
                    • moparmat2000
                      16,110
                      5323
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      5:29 AM
                      Very true, but at the time I was fixing this thing, and was solution i came up with.
                    • Killer6
                      2,430
                      808
                      Mar 9, 2015
                      PA
                      Local Time:
                      5:29 AM
                      Gotcha, been there........in 40+ years of working on stuff, I've gotten it done,...& later said"why didn't I just?" after the fact. A lot more in the early days for sure, lol!
                    • moparmat2000
                      16,110
                      5323
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      5:29 AM
                      It's called "sperience". Back then I had less of it. I was in my mid 20s and just needed it to work. If I had that issue now, I woulda just grabbed some 2.2 headbolt washers out of my stash. Heck what am I talking about here (scratching my head at that absurd thought). Actually I woulda just jerked the whole thing out pegleg rear axle, front drums and all. Woulda dumped it all in my scrap trailer, and installed a magnum 360 / 46RH combo out of a ram van or pickup. Along with a ford explorer 8.8 to round it out, and with M body disc brakes in the front and never looked back
                    • Killer6
                      2,430
                      808
                      Mar 9, 2015
                      PA
                      Local Time:
                      5:29 AM
                      Now now!! :poke:
                      None of that!!^^^
                    • Slantsix64
                      Slantsix64 Well-Known Member
                      2,459
                      916
                      May 11, 2014
                      SGV
                      Local Time:
                      5:29 AM
                      If its all stock mill .100, and have your dizzy recurved as well,you can reuse stock push rods.
                    • Charrlie_S
                      2,902
                      740
                      Oct 17, 2005
                      Silver Springs, FL
                      Local Time:
                      6:29 AM
                      And what CR will that be?
                    • Slantsix64
                      2,459
                      916
                      May 11, 2014
                      SGV
                      Local Time:
                      5:29 AM
                      Depending on year on 225 piston height and gasket 9:1 to 9:5. My stock 78 225 had pistons .170 in the hole cut my slant head .100 to .45cc heads that motor barely got to 9:18:1 But that had me at a cranking psi of (155-160) from a weak 120psi previously my other slant six 1966 block had the pistons closer up .120 in the hole got me in the 9:4:1 range after everything was calculated, its not rocket science although a 170 engine has the piston height higher almost flush to the deck so i would watch out for that .100 cut will get you close to 10:1 on a 170.
                      • Like Like x 1
                      • Charrlie_S
                        2,902
                        740
                        Oct 17, 2005
                        Silver Springs, FL
                        Local Time:
                        6:29 AM
                        That is exactly my point. Unless you measure, you don't know for sure. There is a large difference in tuning, and octane requirement between 9 to 1 and 9.5 to 1
                        Also the cam makes a big difference in what CR will work. My 170 street driver is a "true" 9.5 to 1, with the mildest Mopar performance cam. It likes 93 octane. I was able to use 89 octane, with a lot of distributer work. Would have been better with 9 to 1, or a bigger cam.
                        • Like Like x 1
