'Shift Command' Makes the trans shift manually into first gear AT ANY SPEED. If you want Shift Command feature install Command Plate on challel casting and grind GOVERNOR VALVE as shown'
...Why would you want to shift into first at any speed? I dont think I know anyone that wanted that feature incase you fumble something trying to go 3-2 and you accidentally hit one going 60mph...you do NOT want to hit first at that speed (or whatever your gearing may be. I have 3.91 and a low gear set...first gear is very short in my car (mph wise).
just what we were thinkin,just my 2cents
