shift improver kit
rbkt65
jerseyville, illinois.
for a 42re/44re. street car only. i have the aftermarket manual valve and pressure reg valve. 5.9 magnum, dana with 3.55 gear. will have the factory fi and throttle cable. total rebuild. tia.
can't get an answer from anyone, so 2nd question, who is the transmission parts guy that is a member here from colorado, i think.
That's because you didn't ask a question.
If you were trying to ask about a shift kit recommendation, you did a poor job. But just in case that was it, I like the Superior Transmission kits. They are formerly known as Fairbanks.
