Shift Light Trouble
TONY GTS
I have the proform adjustable shift light & i have the MSD 6a series igintion.
http://store.summitracing.com/partd...part=PRO-67005C&N=700+304978+115&autoview=sku
i wired up my shift light according to directions (red wire to iginition source, green wire to MSD tach output, and black wire to ground) and when i flip my ignition switch on the shift light stays on constant
i set the rpm to 3000 & when my car does 3000 it doesnt matter the shift light stays on constantly.
Problem solved, the shift light was grounding itself out on the steel dash
Im glad thats all it was. Kinda like the Staples commercial: "That was easy"!
when i called proform he asked where i mounted it, i said on a steel dash & he knew right away. thx
