trial and error is what it will take to get it right. There is not one right answer here.
if you peak 6100 and then the HP drop like a rock.....you had better be shifting sooner the 6100.
If the peak HP fall slowly, then running above peak might be advantageous.
shift 500 before beak, make 3 runs, shift 500 higher and see what your ET slip tells you.
