shifter adjust
washington
ok so i have a 904 with reverse pattern valve body and t/brake
also using b & m magnum grip pro stick shifter
the problem i am having is when i adjust drive and 2nd like b&m says i lose
park cog
i am wondering if the arm on the trans is wrong because we are talking like a 1/2" off
all help would be greatly appreciated
mike
Do you have the instructions for it, if not go on the net and find a copy, mopar ford and gm all use different distance between rev and park.
