Shifter boot
Will_H#24
Levittown Pa.
I'm planning on putting a pistol grip shifter in my 69 Dart 340 4 speed. For those of you that have done this, did you use your original Hurst shifter boot or did you use a different one? If so, which one did you use and where did you get it? Thanks
Use can use the Hurst flat stick boot, from Summit, Jeg's, or Brewers.
We make the original style 67-76 A-body boot with the rectangular hole for the PG.
http://www.brewersperformance.com/proddetail.php?prod=SB764R
