shifter detent
abdywgn
dismantler
Darien, Illinois
for reverse manual pattern on the column.Who produces these and are they available for cars other tahn early B-bodies?Thanks,Bob
the valve bodies are the same, installing one and hooking it up should do it. follow the instructions, you won't need the accumulator spring or the governor weights in the in the output shaft but if it's too much trouble you can leave them in the output shaft.
Thanks for the info...I'm guessing my question is not worded right.I am looking for the plate that goes in the steering column to work with a rmvb.Remember seeing them somewhere but at a lose for who.
