[WANTED] SHIFTER MOUNT BRACKET
SSing
upland, sweden
Pictured (from Jim Schild´s SS Guide) is the back side of the special Mounting Bracket used on the ´68 Hemi A-Body 4-speed cars.
Yes, it´s a long shot, but figured I try…
Thank you, Stefan
Thank you.
Yes I have one made, but I´m not quit pleased with it, now that I´m gonna go with no rubber boot...
How much is yours?
They will be laser cut a little more but the com out nice. depending how many I have made 50 to 100
I have one that I am using but if you cannot find one. I will have some made.
I need one too Dave, I am also considering making it since the dimension are listed in the book. If you do decide to make them, I will buy one!
I just made some Ram Rod A body brackets. This is how clean they will look. I am going their tomorrow
Thanks.
Yes, looks very good.
Was finish of the original adapter bracket semi glossy, or how do you describe it?
Ok thanks, Jim Schild calls it black enamel painted. Sounds like yours have been repainted...
Makes sense...did they require different shift rods as well ? Or just angle the shifter back towards the driver more ?
Again according to the Guide, a picture show they look beefier and the reverse rod runs a bit different. Rod lengths may have been the same, since a Competition Plus Shifter was used, and since they can be adjusted with the treads...
