smokindust
I have a short deck R3 block with nascar W8 cnc heads with extra parts that I have decided to sell. The block has Jesel keyway bushings installed. Billet steel 4 bolt mains 60 mm cam tunnel, 4.15 bore, I have a sonny Bryant 3.30 stroke crank to make it a 360 cid. I have a 60mm UGL cam. Carrillo steel rods slightly used, Jesel .937 lifters slightly used. New 598 MP intake. New W8 bare heads with copper berluimun valve seats installed 2.25 intake 1.65 exhaust, magnesium valve covers. No pistons, or Valvetrain. I also have a head studs and cam bearings, but head stud kit is the wrong one but has the hard to find 1/2 to 3/8 that run through the intake runners 7500.00 firm.
