I bought an adjustable pinion snubber for my 66 Barracuda. It's going on the 8.75 rear I have in it with 3-91 gears. Should I weld in a steel plate to renforce the body and should I put the snubber right up against the body or give it a little space
And then post it on here, the video that is.If it were me...
I would get a go pro and record the stock snubber in action.
You might find that it does not come in contact with the body except when there is weight in the rear (like passengers)
It would also pinpoint where and how tall it needs to be to be effective
