Show me your SB valve covers with EVAP breathers
pettybludart
Ontario,Canada
I,d like to see what some of you racers are running for valve covers with EVAP system.I,m thinking about buying some new race valve covers for my new stroker build.Let's see them!
Hey Scott, hope you plan on letting me see them second. ;-) It would be sweet to have a hand in that new ride of yours too.
I put the stock valve covers that allow the use of the big Mopar breather. Have them on both sides with the 5/8 hose dumping down by the header collectors, zip tied in place. Seem to work OK but it was also in keeping with the skipiness theme of the PO. They are painted to match the block.
Very cheap,but you have to watch the size of hose or it will suck oil out of the engine.
You'll see this after run with oil dripping from collector.
Nice setup womanator,but looking for small block(SB)valve cover setup.Basically looking for what others are using for valve covers(type,brand)on their small block race cars.Thanks
Scott,
I used Mopar Performance v/c's and the breathers with 45* on them, with the grommets and the s/s wrapped hose. They have the pseudo AN collars with screw clamps. I'll try to get you some pics, PM me your email addy.
Bill S.
Oil running out of the breather hoses huh? May explain some leakage I am seeing. What can I do differently then and still breath the beast?
Scott,
Bill S.
Hey Bill,I already have MT valve covers with EVAP setup,just wanting to change valve covers to something different for rave application.I guess I,ll check Mancinis and Summit to Ed what they carry.Thanks
Look into a set of the fabbed valve covers. I saw a set on a 72 Dart at the track a few weeks back. They were mirror polished, with the breathers painted black with black hoses. I think they looked trick and I'm tempted to do it to mine, but I bought the NRS v/c's here and as soon as I can afford it I'm sending them to Leanna to be custom coated.
Bill S.
